bbeanan Posted July 27, 2018 Share Posted July 27, 2018 So I am inserting a KARA line array and (using the Line array tool with my own numbers and saved to the library) But it will not connect to the truss so I can add the load any suggestions? Quote Link to comment
SCParker Posted September 14, 2018 Share Posted September 14, 2018 I run into these issues often for various reasons. I find it easiest to add a simple point load at the same location and ignore the weights in the array tool. Handy also when the audio dept. changes gear and doesn't update the array tool with accurate weights. Quote Link to comment
Wesley Burrows Posted September 26, 2018 Share Posted September 26, 2018 Along these lines I don't understand why you can't (or I can't) seem to get a single hoist to grab the load info from the Line Array tool let alone connect to it. (single point array). If I stick a point load under the hoist with the weight of the array and same Z value of the motor, that works. What am I doing wrong? Or is it really that stupid? Quote Link to comment
Ryan Seybert Posted November 29, 2018 Share Posted November 29, 2018 The trick seems to be move the Array to the motor point or the truss. The motor point or the truss will do its little red thing and then it'll connect. 3 Quote Link to comment
Wesley Burrows Posted February 18, 2019 Share Posted February 18, 2019 On 11/28/2018 at 11:54 PM, rseybert said: The trick seems to be move the Array to the motor point or the truss. The motor point or the truss will do its little red thing and then it'll connect. Not sure how I'm just seeing this but thank you! It worked! There seems to be little in the way of continuity between how difference devices attached to motors and stuff. Quote Link to comment
Endre Torkildsen Posted July 18, 2019 Share Posted July 18, 2019 @rseybert On 11/29/2018 at 6:54 AM, rseybert said: The trick seems to be move the Array to the motor point or the truss. The motor point or the truss will do its little red thing and then it'll connect. Have been trying to find a fix for this soo many times, thank you for the tip! Worked just perfect! Quote Link to comment
