Issues with Tile Fill
Good morning all,
I having a few issues with the tile file. Managed to create my own tile within the resource manager and apply them to a simple object. The first issue is once it is applied, the fill seems to flicker, fade, disappear o only partly show when I zoom in and out of the drawing, both in design layer and sheet layer.
Second issue is that when I publish the sheet, the tile fill only partly shows on the PDF (see image attached, you can see the tile file on the left elevation but not on the right section). I have tried rasterizing and lowering the DPI count the PDF when publishing and changing the VWs settings the best compatibility.
Im using VW 2018 Architecture, Windows 10 pro 64 bit on a HP 250 G6 Notebook PC.
Thank you
209.010-Proposed Bathroom Specification -Princes Sq. .pdf
Edited by twhitwell6
  • 1 year later...
