Arrowheads
Polylines can't take arrowheads in the same way as lines and arcs. But some people add an arrowhead as a separate object. One way to do that is to make a symbol consisting of one very short line with an arrowhead on one end. You can adjust it so the line is the same length as the arrowhead. Then insert the symbol at the end of the polyline, and rotate it as you insert it to align with the polyline.
