NumCustomObjectChoices(pioName, pParamName)
It seems that I am unable to get "NumCustomObjectChoices(pioName, pParamName)” to yield anything but “0” When it queries a dynamically loaded dropdown.
The “AP Multicable” plug-in object has a “Break Out Type” field that is loaded from an XML.  There are AP Multicables on the drawing and the Preferences OIP shows all the choices, but NumCustomObjectChoices('AP Multicable', PBreak_Out_Type) yields “0”.
The function description says to use the PForm of the parameter as I do above, but I have also tried it with “ Break Out Type” with the same result.  The function is used in a selection procedure and not in an object.  What am I doing wrong, or am I just screwed?
TIA,
  • 2 months later...
