Mikedk64
light inside a sign
Hi,
I have this sign in red, that i want to light up when its dark.
I have tried to look around for a guide or similar, but cant find anything.
Any suggestions?
I believe :)
I have these images.
The black is the frame, so it is only the red part, that i want to light up.
The best and quickest way to do this is to apply a texture to the "Red" Geometry.
  • In the transparency shader of the texture, set it to glow. Set it to emit light if you want to see some light from it on other objects and also, to give it the appearance of being solid as well, you could add matt reflectivity.
  • In the colour shader you can either set it to "Object attribute" which will inherit the fill colour or pick another colour that you prefer.
  •  You may want the default lighting to be off in order to see it properly. If so, then you need to add a light object to the scene. It can be turned off, it just needs to be there in order to tell the default lighting to turn off.
  • You may need to apply a much higher value than 100% in order to see your glow.
  • You need to render in a renderworks setting, Custom renderworks with the settings down at low is best to see it quickly.
Hope that works ok for you
Mark
  • Like 4
Additionally, in order for the "emit light" option to have any effect, make sure that Indirect Lighting is turned on in your Render Style.
  • Like 3
yeah, that as well!
okay thanks,
Could it be possible for one of you to make a file, with a similar sign (Just for illustration) and with the correct settings, textures and so?
@markdd that is cool. It is exactly what i was looking for! :)
Now i just need to figure out how I make a good realistic render style.
As far as render styles go, it is a bit of trial and error. It completely depends on what kind of scene you are creating. If its an exterior then choose exterior indirect lighting because Renderworks won't look for a ceiling to bounce off.
Otherwise, build up on the renderworks style I made in the file. Tick the various options as you need them. You will notice that I set the curved geometry to high so the curves on your sign render smoothly, and I put indirect lighting at medium so that the light from the sign renders smoothly on the surrounding box. It can become "splotchy" if the settings for this aren't high enough (however there seems to be a very welcome improvement with this over the last few service packs).
Its all very subjective, and there is a really good video playlist that@Jim Wilsonmade on the youtube channel. The video below is about Renderworks Styles, but the whole series is well worth a look.
This playlist is also very good. Also this video might be helpful for what you want to achieve.
Edited by markdd
