cwailes Posted July 19, 2018 Share Posted July 19, 2018 (edited) I added a small component to a wall style and it does not go all the way to the edges of the connecting walls. It falls short, and I am not sure what is causing this. What do I need to change to make it be continuous on all connecting walls? Edited July 19, 2018 by ccw Quote Link to comment
cwailes Posted July 19, 2018 Author Share Posted July 19, 2018 Is there a setting that controls the horizontal offset of a component/material? I see the vertical offset but not horizontal. It does this all the way around the structure. Quote Link to comment
RGyori Posted July 19, 2018 Share Posted July 19, 2018 Just a wild stab... after adding the wall component did you apply the Remove Wall Breaks Tool to to the corner and then rejoined? Quote Link to comment
cwailes Posted July 19, 2018 Author Share Posted July 19, 2018 Don't think I did but not sure. Will have to look into that later when I get home. Quote Link to comment
cwailes Posted July 20, 2018 Author Share Posted July 20, 2018 Using the Remove Wall Breaks tool and then rejoining worked. Thank you, RGyori. However, why doesn't this just automatically work? Quote Link to comment
RGyori Posted July 20, 2018 Share Posted July 20, 2018 @ccw, glad it worked. I do agree with you that using the Remove wall Breaks tool is a hack. It really shouldn't require the extra steps. Quote Link to comment
cwailes Posted July 20, 2018 Author Share Posted July 20, 2018 27 minutes ago, RGyori said: @ccw, glad it worked. I do agree with you that using the Remove wall Breaks tool is a hack. It really shouldn't require the extra steps. I agree, I had to go back and redo every exterior corner connection which was a lot of wasted time I could have been doing other things with the design. Quote Link to comment
