Wall Component Problem
I added a small component to a wall style and it does not go all the way to the edges of the connecting walls. It falls short, and I am not sure what is causing this. What do I need to change to make it be continuous on all connecting walls?
Edited by ccw
27 minutes ago, RGyori said:
@ccw, glad it worked. I do agree with you that using the Remove wall Breaks tool is a hack. It really shouldn't require the extra steps.
I agree, I had to go back and redo every exterior corner connection which was a lot of wasted time I could have been doing other things with the design.
