sbarnett Posted July 18, 2018 Share Posted July 18, 2018 Vectorworks Does not handle a second screen when used with a 4K laptop using Display Scaling. I have a new GT75 MSI laptop with a 4K display. Set to 200% scale second monitor is a LG 3440x1440 as soon as you drag Vectorworks to the second monitor it crashes and you have to end task. I am forced to only use the second monitor and turn off the laptop display if I wish to use the wide monitor. Buyer beware until they can figure out how to handle display scaling Quote Link to comment
0 Anthony Neary Posted July 20, 2018 Share Posted July 20, 2018 I don't have the crashing issue, but even on a non-4k display I end up with scaling issues with the second monitor at 100%. It grabs the scale from whichever monitor the main window is on it seems, which can throw off the pallettes on the other. I run my secondary monitors at the same scale as the laptop display, 125%. Does that fix your crashing issue if you set your off-board to 200% as well? Quote Link to comment
sbarnett
1 answer to this question
