  • 3
Using Records To Modify Objects
GlueDT92
I often wish I could change object attributes using record formats. For example, I have a symbol that has a piece of text contained within it. Depending on when the symbol is going to be installed, I color the text red, blue, or purple to indicate installation timing to my team. As it stands I have 3 different symbols, 1 red, 1 blue, & 1 purple for each situation. It would be amazing if there was a way to create a record field that allowed me to select the color of the text depending on the situation - that way I could have a single symbol with an associated record.
  • Like 3
1 answer to this question
