AndyM Posted October 8, 2004 Share Posted October 8, 2004 Is there a way to copy sheet layers with all of their viewports and everything? That would be a huge time saver. Quote Link to comment
CipesDesign Posted October 8, 2004 Share Posted October 8, 2004 You can copy everything that's ON a sheet layer (symbols, title blocks, viewports, etc.). Does this help? Quote Link to comment
AndyM Posted October 8, 2004 Author Share Posted October 8, 2004 I would like to be able to duplicate an entire sheet layer with print settings and viewports. Then when you are doing multiple veiws of a model you could just edit the crop of the viewport and you're done. Much easier that creating a new sheet layer, setting up printing options and pasting the viewports. Quote Link to comment
CipesDesign Posted October 8, 2004 Share Posted October 8, 2004 Hey Andy, That would be a nice thing to put on the wishlist. As it is now, you can kind of do it. If you create your first sheet layer with all the appropriate print size settings, all the following ones that are created will default to the same page size as the first. Unfortunately you will still need to manually set the DPI and manually copy and paste all the data (objects) from one to the other... Quote Link to comment
