nahekul
Converting Unstyled to Styled Wall Bug
Vectorworks Architect 2018 SP4 (Build: 435714) (64 bit)
The bug occurs when trying to convert an unstyled wall to a new wall style using the right-click context menu.
To recreate the bug:
- select some unstyled walls and create a group.
- exit the group with the walls still selected (selected walls inside the group are shown as not selected outside).
- create another unstyled wall that's different than the first one.
- right click on the new unstyled wall and turn it into a styled wall.
- pop up menu will come up asking to replace all selected walls (no ways to not replace the walls).
- clicking ok will now change all the selected walls in the group to the new styled wall even if the group is unselected and on another layer.
There is no way to tell if something is selected in the group unless going into each group on every single design layer to check manually.
The workaround currently is to copy the unstyled wall to a new file and turn it into a styled wall in the new file.
0 answers to this question
