aboverocks Posted July 10, 2018 Share Posted July 10, 2018 Hi there, I'm new to Vectorworks and this forum, and using Vectorworks Landmark 2015 with Renderworks. I'm creating a garden for wheelchair users and have made good progress using the tutorials on the Vectorworks website. I've imported my .dwg Landscape Survey, created a 3D model of the existing barn onsite, with door and roof, in a layer called 'landscape plan', and drawn out the design (paths, ramps, landings, beds, lawn etc.) in 2D in a layer called 'draft plan'. Using hybrid tools/hardscape tool, I would now like to convert the 2D draft plan into a 3D model around the barn, with all the different areas at the correct levels, with ramps and lawns at the correct gradients, and I'm struggling! The tutorial I've been following ('Getting Started Guide' on the website) uses different layers set at different levels for each terrace, another tutorial speaks of using the stake tool with site modifiers. I appreciate there are always different ways to do the same thing, but I would be so grateful if someone could explain a tried and tested workflow/ document organisation to help me with this. I've tried searching the forum but haven't found a way to get this information. Thanks in advance. Quote Link to comment
jpccrodrigues Posted July 11, 2018 Share Posted July 11, 2018 Hi, What I usually do is to work either with Pads (Site Modifiers - Pad) or Hardscapes and draw the plan. I attach an example so you can take a closer look both of the commands (just an example, just to demonstrate the tools). Good luck!! TEST_v2015.vwx Quote Link to comment
aboverocks Posted July 31, 2018 Author Share Posted July 31, 2018 Thanks for the help jpccrodrigues! Quote Link to comment
