djobbins 0 Posted July 6, 2018 Hey I'm having an issue w/ my VW2018 spotlight. I had VW lock up on me and did a force quit. When I opened it again a bunch of my lighting instruments seem to be disappearing. They will reappear when I toggle classes (any classes) on an off, but will disappear when I try to zoom in or go into a 3d view. I have 3d viewports that still display the instruments correctly, but when I try to edit the design layer via the the viewport the instruments disappear again. I thought it was something wrong with the symbol geometry, so i tried to re-import the symbols into the file, but I didn't even get the usual "this symbol already exists..." message when I reimported. Any thoughts? Quote Share this post Link to post
scottmoore 317 Posted July 7, 2018 (edited) That has been an ongoing bug since at least 2017. Exceptionally annoying. “Refresh Instruments” generally solves it. I believe the initial intent of that command was to update symbols when you did things like swap instruments or whatnot. That is perhaps understandable, however, it has become a constant workaround for this issue. Command / is the keyboard shortcut. Did I already say exceptionally annoying? Edited July 7, 2018 by scottmoore 1 Quote Share this post Link to post
Guest Texasguy Posted July 11, 2018 I have had the exact same issues. It doesn't happen all the time, but quite frequently. It typically happens if I zoom out some of the fixtures go away. I have to turn that class off and back on again and they reappear, but if I zoom they go away again. I too noticed that starting to happen in 2017. I agree with you Scott....VERY annoying! Not acceptable when you are drawing a lighting rig and the instruments disappear at will. Vectorworks can you please fix this problem? I paid $3,200 for the program and almost $700 each year for service select. I feel that this should be fixed. Thanks. Quote Share this post Link to post
