Scott61 Posted July 5, 2018 Share Posted July 5, 2018 I have drawn a series of columns, and simply drew one side copy and pasting from the original column, then mirroring them over to the opposite side. As I was drawing I noticed that I had duplicates of all the columns. As I am learning the program I figured it was my mistake and deleted the duplicates and went on, all was as it should be after I deleted the duplicates, 6 columns each side. Now the issue.... I am suppose to have 6 columns each side, but in plan and axon I have 4 on one side and two on the other...but in elevation I have all 6, both sides! Why would they appear and disappear like that? They are all same layer and same class. Thanks for help! Quote Link to comment
Peter Vandewalle Posted July 6, 2018 Share Posted July 6, 2018 We’ll need the Vectorworks file to be able to solve this issue. Quote Link to comment
Scott61 Posted July 6, 2018 Author Share Posted July 6, 2018 Uploads keep failing, the file is only 101.7MB, are there other ways to get you the file?. Thanks Quote Link to comment
Kevin McAllister Posted July 6, 2018 Share Posted July 6, 2018 41 minutes ago, Scott61 said: Uploads keep failing, the file is only 101.7MB, are there other ways to get you the file?. Thanks I would delete the extraneous information in the file not needed for troubleshooting and make sure the file is rendered in wireframe before saving. Kevin Quote Link to comment
Scott61 Posted July 6, 2018 Author Share Posted July 6, 2018 Deleted everything except pertinent layer and still get error -200. Is there an index of codes? Quote Link to comment
