Sam Jones
Page Setup (Size) for Sheet Layers
Is there a way to access the stored page size of a sheet Layer, and is there a way to set the page size of a sheet layer.  I have been able to get the sheet titles from the description GetObjectVariableString(theLayer,159), but can't find access to the page size.
Try SetDrawingRect and see if that will do what you want/need.
If not, I think you will be stuck with opening the dialog box using DoMenuTextByName.
You can use GetDrawingSizeRect() to establish the current page size, and SetDrawingRect() to set a new page size.
Unfortunately, they don't work.  GetDrawingSizeRectN() yields a rect(x1, y1, x2, y2).  When applied to a sheet layers every sheet layer yields
x1 = -5.5
y1 = 4.25
x2 = 5.5
y2 = -4.25
Essentially an 8.5" x 11" sheet, no matter what the page setup is for the sheet layer.  The GetDrawingSizeRectN() is querying empty sheet layers that have different page setups.
Anything else I should try?
Just for background.
I am writing 2 scripts: "WriteLayerStructure" and "GetLayerStructure".  The object is to write layer to a file and to read it back into another file.  Everything works great, except sheet layers don't get their page set up written and read.  I don't care about design layers.  Don't bother bringing up templates.  The scripts are used to bring a layer structure into drawings sent to me by other people.  Actually, the script is for others who are anxiously waiting.
Thanks,
S
It works for me Sam. Try this script as a test:
Procedure T;
VAR
    x1, y1, x2, y2, ScaleFactor : REAL;
BEGIN
    ScaleFactor := RealDialog('Scale Factor:', '1.5');
    GetDrawingSizeRectN(ActLayer, x1, y1, x2, y2);
    SetDrawingRect((x2 - x1) * ScaleFactor, (y1 - y2) * ScaleFactor);
    Message((x2 - x1) * ScaleFactor, chr(13), (y1 - y2) * ScaleFactor);
END;
Run(T);
Make sure you get the units right tool. Can't remember if it uses document units, mm or inches.
Also, I would assume that GetDrawingSizeRectN would use the same units.  As long as I want the same units, would I need to care what they are?
Scale factor is only there to demonstrate the script. If you run the script with the default setting, it should make the page size 1.5 times larger.
If you are the only one using your script then I agree units should not be an issue. If it is anyone else, then the values you are storing should have unit marks so they allow for it. People will always to the unexpected.
Then I don't know what's happening.  The script below writes 8.5 x 11 dimensions for all the sheet layers.  Those sheet layers have different page setups between 8.5 x 11 and 36 x 48.
PROCEDURE WriteLayerStructure;
{DEBUG}
TYPE
    DrawSizeInfo = STRUCTURE
        x1 : REAL;
        y1 : REAL;
        x2 : REAL;
        y2 : REAL;
    END;
VAR
    CurrFileName : STRING;
    LayerNum : INTEGER;
    LayerArray : ARRAY[1..100] OF STRING;
    LyrDescrArray : ARRAY[1..100] OF STRING;
    ScaleArray : ARRAY[1..100] OF REAL;
    LTypeArray : ARRAY[1..100] OF INTEGER;
    LDrawSize : ARRAY[1..100] OF DrawSizeInfo;
    PROCEDURE CollectLayerInfo;
    VAR
        theLayer : HANDLE;
        layerName : STRING;
        layerDescrip : STRING;
        theScale : REAL;
        theType : INTEGER;
        lyrNum : REAL;
        x1, y1, x2, y2 : REAL;
    BEGIN
        layerNum := 1;
        theLayer := FLayer;
        layerName := GetLName(theLayer);
        IF layerName = '0' THEN
            layerName := '000';
        theScale := GetLScale(theLayer);
        theType := GetObjectVariableInt(theLayer,154);
        layerDescrip := 'zz';
        IF theType = 2 THEN
            layerDescrip := GetObjectVariableString(theLayer,159);
        IF (layerDescrip = '') THEN
        GetDrawingSizeRectN(theLayer, x1, y1, x2, y2);
        LayerArray[layerNum] := layerName;
        LyrDescrArray[layerNum] := layerDescrip;
        ScaleArray[layerNum] := theScale;
        LTypeArray[layerNum] := theType;
        LDrawSize[layerNum].x1 := x1;
        LDrawSize[layerNum].y1 := y1;
        LDrawSize[layerNum].x2 := x2;
        LDrawSize[layerNum].y2 := y2;
        theLayer := NextLayer(theLayer);
        WHILE theLayer <> NIL DO
        BEGIN
            layerNum := layerNum + 1;
            IF ValidNumStr(layerName,lyrNum) THEN
                layerName := CONCAT('zz',layerName);
            {layerDescrip := GetObjectVariableSTRING(theLayer,159);}
            IF theType = 2 THEN
                layerDescrip := ' ';
        END; {WHILE theLayer <> NIL}
    END; {PROCEDURE CollectLayerInfo}
BEGIN
            CurrFileName := GetFName;
            CurrFileName := CONCAT(CurrFileName,' ','Layer List');
            CollectLayerInfo;
            PutFile('Name and Save the Layer List File',CurrFileName,FileName);
            IF NOT DidCancel THEN
                BEGIN
                    WriteLn(LayerNum);
                    FOR Index := 1 TO LayerNum DO
                        BEGIN
                            WriteLn(LayerArray[Index]);
                            WriteLn(LyrDescrArray[Index]);
                            WriteLn(ScaleArray[Index]);
                            WriteLn(LTypeArray[Index]);
                            WriteLn(LDrawSize[layerNum].x1);
                            WriteLn(LDrawSize[layerNum].y1);
                            WriteLn(LDrawSize[layerNum].x2);
                            WriteLn(LDrawSize[layerNum].y2);
                        END; {FOR Index := 1 TO LayerNum}
                    CLOSE(FileName);
                END; {IF NOT DidCancel}
            AlrtDialog('Done Writing Layer List');
END;
RUN(WriteLayerStructure);
Dunno Sam. Maybe is it working of the active layer and not the layer you specify. Try making each layer active before getting the layer into. If you do this, then you only need to use GetDrawingSizeRect() which returns info from the active layer.
I thought I sent a note late last night.  I found the problem; I was using the wrong index in LDrawSize[ ]  variable.  Never code after dinner, if wine is served.
