DonMiki
mac os mojave beta
Hi, I installed Mac OS Mojave public beta and Vectorworks slows down maximally. Is anything I can to repear it or I must down the system?
We do not support any beta operating systems, apologies. I recommend keeping any important production hardware on the release versions of macOS only.
Your best bet is to reset Vectorworks preferences:
That OS beta is around a day old, so it's unlikely any workarounds for it have been developed by the userbase or any employees here yet.
Then in that case I recommend returning to a previous OS version, we will announce once one or more versions of Vectorworks is compatible with Mojave.
I Installed it too, just for fun, VW was incredibly slow, so i went back to High Sierra.
Tanks for the early adopter experiences.
That's Metal 😉
That's Metal 😉
Except that OpenGL support hasn't gone away or changed at all in current. It will at some point in the future but not likely in the next 2 years.
Edit to add:
Unless your being paid to do it. Running a beta is just not advisable.
VW pays people to suffer that fate, indeed some group of damned souls inside NNA headquarters is probably running VW2019 alpha or beta on Mac OS beta. Let them get on with it and go back to your High Sierra boot disk.
Edited by Matt Overton
To add.
That was a joke.
Yes, Support is gone away, as it it will no longer be upgraded or enhanced.
Yes, OpenGL is still there in Mojave.
If OpenGL will still be in any Mojave's successor, is solely Apple's decision.
It is likely that it will last some years, but Apple made a lot of other decisions
with negative impacts that I wouldn't bet that it will stay for many years.
But now as you mentioned ....
So why will VW be so noticeably slower in first Mojave Beta ?
I don't think there are many critical changes in CPU usage that could slow
VW down very much.
I rather tend to think that they indeed deactivated OpenGL in the first Beta
and now every former UI interaction and display, previously running in GPU
hardware acceleration, now is running in slower CPU Software
emulation mode.
Just to give developers a small glimpse of how the future of their Software
will look if they don't do what Apple told.
(Just pure speculation)
Beta's are fuzzy at the edges, Vectorworks is an edge case that uses very little system UI and who knows what over cross-platform tricks. So it could be almost anything and there are people in NNA and Apple who's job it is to find the friction.
I'll let them speculate and build test cases.
Now you have betrayed that there will be a VW 2019 at some point .....
Nothing change after installing beta 2. But it is true,  when I closed Object info palette VW runs faster.
Hello to all:
I install VW in each Beta I tested before to preview if I must update all my software when the final release appear.
In my experience, working since VW 2008, when update to Yosemite must update to 2014, after that with El Capitan, 2016 was the choice. Now I always operate with High Sierra Beta, and VW 2017 works perfectly. But Mojave is other thing because Apple left to work with Open GL and CL, then I think some troubles will appear using Metal.
For that, I suggest maintain High Sierra to work efficiently.
Regards.
if it's an opengl issue, then maxon will have to switch to metal for cinerender, too. because there comes archicad as well...
i only hope that mojave will improve for this issue, because for the new computers it'd mean to go back to the previous os versions.
OpenGL will still be available in Mojave and maybe in further macOS releases too.
And OpenGL is also available in the Beta. Didn't read of any problems with other
OpenGL software so far.
As Jim said, it was just a Problem with a indigestibility of the Object Info Palette's
Code that made VW lag.
As far as rumored, C4D will do a Metall version for Apple
(or Apple may help and do it (partly) for them)
Nearly all 3D DCC or CAD App on Mac (or in general) uses and needs OpenGL
and is therefore effected in some way by Apple's decision.
lacking apple support for opengl _is_ an issue for macintosh machines, and a big one.
and, regardless of opengl presence in mac os, it really matters if vw still keeps opengl for the future releases or not.
the sooner maxon introduces metal for cinerender, the better.
Edited by gester
Testing Mojave as well, also with VW2018.
I can confirm that it is lagging a lot. Turning off the Object palette helps and as a workaround you can enter Values via right click-> properties.
Also I noticed that since the newest Beta it looks like things speed up a bit but it is still slow but workable.
But apart from that startup is quite slow as well.
Haven't found any other major problems by now.
If you really need VW2018 fully working and you don't have a different computer than your productive system then absolutely DON`T update....
1010227437_Zrzutekranu2018-09-25o12_08_09.thumb.png.da5164267858d34df816efb1e0786472.pngFinal OS Mojave still does not work properly with VW 2018, for example: problem with palettes... empty container  😞
Edited by DonMiki
OS Mojave - VW 2019 - files created in older VW does not work...
Edited by DonMiki
2019 shows all of the pallets, but still has extremely slow performance on Mac OS Mojave. When can we expect a service pack to fix these issues since Mojave has officially be released?
I see strange lags when working with Navigation Palette,
but can't see anything spectacular about the OIP so far.
Mojave Release is macOS 10.14 (18A391).
I read that latest Beta was something like (18A398) already.
Does someone have the release number of the macOS Beta where VW ran well or better ?
