Developer Wiki and Function Reference Links Read more... ×
elepp
Scale awareness of object nodes
Hi Folks,
maybe one of you has a good idea of how to solve this problem. I created an object node that reads the content of a database, that is attached to a symbol. I want to use it as tag for windows. Is there a way to have it react like a symbol to changes in the drawing scale? I would like to have the possibility to choose the size of the tag to be either absolut or relativ to scale. I assume there is no node, that would facilitate that.
Any input would be greatly appreciated.
Kind regards,
Ed
To clarify my issue, if attached a screenshot and my file. In the screenshot one can see that the size of the object node always adjustes itself relativ to scale in a viewport on the sheet layer.
Window Tag.vwx
I am not sure if it is possible to tie objects to viewport scale or annotation space, but there is a command that reads layer scale and you can use that to scale your tags if they are being placed in the design layer. I created a node that gets the layer scale that an object is in - if the scale is 1:1, the node will return "1" and if the scale is 1:50, the node will return "50." This was based on the Get Layer node, I just added a command to get the layer scale instead.
GetLayerScale.vwx
HTH,
Sarah
I think you would need to have your Marionette network place a page based symbol as the "tag" object. The symbol would be a couple of pieces of text linked to records and the Marionette network would need to write to those records. A page based (green) symbol updates based on sheet layer scale. The only thing I'm not sure about is how dynamically this would update and keep current.
Kevin
I'm looking into making this work. There are some commands that will return Viewport scale, I just need to see if I can get a Marionette object to work correctly inside of an annotation group. I'm trying to avoid inserting page based symbols because I can't guarantee their reliability. They would almost definitely require a manual reset.
I'm running into a problem where Marionette Objects in the annotation group won't allow you to edit their contained script so it's taking a little longer than I would have hoped.
We haven't tested workflows with Marionette Objects in viewport groups, so bear with me, and rest assured that I'm logging all of the issues I'm finding 🙂
GetLayerScale.vwx
HTH,
Sarah
Thanks for the reply and file. I'll see how I can use it in my workflow. 😀
Is it though possible to do it on the design layer? I would place the object node on the design layer and create two viewports with different scale. I would prefer it that way for now, because I have to select each custom window symbol to get its ID. The ID then gets typed into the object node to retrieve the information from the custom data base.
If I insert the object node in the annotation group, that would not be possible, right?
