Sam Jones
Accessing PIO defaults with dynamically filled pull downs.
I have a cable PIO that has a dynamically loaded pull down.  When someone draws the cable path the XML file of values is read and loaded into the pull down.  My problem is that the user cannot select from the PIO default OIP (preferences oip) until after a cable has been drawn.  Once a cable is drawn the default OIP displays what was loaded with that last cable draw.  I need for various reasons to have the default PIO dynamically load the the pull down, so the user can make a selection prior to the first cable draw.  How do I do that?  Anyone?
Is this VS or the SDK? Where are you filling the drop down?
I don't have this issue with the SDK. It might be the location/event where you fill the dropdown?
