Onink
Classes won't change in cabinet
When I change the colour of the class my cabinet doesn't adjust to this colour.
I have created multiple cabinets from one base wich works fine.
But the cabinet I have attached doesn't change as you can see for yourself.
I have changed three classes which the cabinet uses, but they all remain white.
Does anyone have any idea, what might be the cause?
Any suggestions or ideas to simplify my cabinet are welkom...
I get the idea this one is made more complicated then needed.
Parametric cabinet.vwx
Thanks for your reply.
Where can I find the settings for 'use at creation'?
I find it a bit odd, because in the original cabinet everything works without the extra node.
See attachment.
Parametric cabinet base.vwx
You appear to already have 'Use at Creation' set. That setting is in the "Edit Class" dialog.
It looks like you have that object set to use the class settings in the attributes palette which is why it works correctly.
If you open the file where it hadn't been working, select the cabinet, and set everything to use class values in the attributes palette, it should also work. It's the manual way of doing what the "Set Fill Color by Class" node would do.
Please let me know if I was unclear.
