  • 28
Organising / grouping sheet and design layers
phin
13 answers to this question
1 hour ago, Matt Overton said:
Yes existing wishes are out there. So if everyone votes up before Jim merges the threads we can really push the vote count up.
Note that @JimW has said votes for merged threads don’t add together, they currently only take the vote count of the oldest thread.
This older thread (already merged) on this same topic currently has more votes, so be sure to go over there and up-vote:
Edited by rDesign
Yes, linear Layers or classes are a bit 90ies.
I don't know how ACAD users can live with their Layers only,
perhaps there is a filter option and they have their Layer states.
Like VW Saved Views but I think you can hide unwanted Layers that way.
VW has its hierarchy but its limited to "-" separator and very unreadable.
I think even simple coloring would help Navi Palette.
What I see more and more in parametric BIM Apps (e.g. FreeCAD)
is similar to how any 3D App with their Object Managers/Item Lists work.
(C4D, Modo, Max, ....) There you have to build your hierarchy manually by
sorting to groups. And these have 3 Visibility States :
- Default/Unchanged (=parented)
- ON
- OFF
So you can shut off the hole content of a parent group folder (like in VW),
while having the option to still force a single element to be visible by forcing
its visibility to ON, which overwrites the parent settings.
And you have access to any single Object.
(Like I don't want to see any Walls - but Wall37)
Bricscad Structure Manager goes a bit further in a way that Hierarchy, Sorting
and Filtering are done dynamically and automatically. This is very flexible.
You can build your own Presets for any sorting to switch for current interests.
Like :
- sort by Buildings and or Stories
- sort by Wall thickness, material, fire rating or structural vs non structural
- hide all things like Doors and Windows.
This way you can easily navigate, to find things like Elements that have
no IFC tagging or any characteristic you like. And "isolate"Visibility to
your selection.
In VW you can also separate Stories by Classes and Layers. And "isolate"
Objects Visibility by Saved Views. Works very easy and fast.
But if you also separate by Buildings you will get another set of Layer
duplicates in a linear list and it gets clunky.
While in the other system you can combine any number of sorting characteristics
behind each other. Like Filter is : BuildingX + StoryX + ObjectType + MaterialType + ...
The needed Folder Duplication in the Tree happens temporarily only and
automatically on the fly.
The Odd thing about this is BIM IFC file standard Space is organized in a hierarchy and allows grouping along the lines we'd want. This is basically the formats analog to layers. Indeed could be a nice upgrade to Layers to make them spaces with boundaries and a hierarchy. Which means there is nothing stopping the user keeping the flat layer structure of the current.
Would also love to be able to import layers (preferably with an assigned colour number for both pen and fill) from a spreadsheet including some outline/folder hierarchy. Sooo much easier than creating all from scratch. - I know a template might help, but there are so many differences between each project in my humble experience.
