avro-designs Posted June 23, 2018 Share Posted June 23, 2018 I'm trying out 2018 for the first time... After finally figuring out that I need to use Unstyled walls, I still cannot change their thickness. The input field is greyed out. Why can't I simply input the wall thickness in Object Info? That used to be possible in 2012 as far as I remember. Quote Link to comment
mike m oz Posted June 24, 2018 Share Posted June 24, 2018 Click on the Components button and edit the width of the single component for that Unstyled Wall. Quote Link to comment
AlanW Posted June 24, 2018 Share Posted June 24, 2018 @avro-designsHi, you may already know this but it’s better to use styled walls with the occasional unstyled wall. You have so much more control over changing the walls later. see video, https://m.youtube.com/watch?v=HdDtMSW7H4c Quote Link to comment
