thomas
Font incompatibility between VW 10 and VW11?
I used to work with VW 10 on a PC with windows 98 and the font I used to use was Arial Narrow. Since I updated to VW 11 my documents are Ok except the texts which are illegible as if they are translated into something else, although it still shows them as being Arial Narrow. It is imperative to find a cure to discard the old version and keep using only the new one.
i have always found Arial to be a tricky font, especially with objects. have you tries a global text select and chaniging the font through the text menu?
Check your font mapping.
You may have it mapped to something
odd. You can fix all your text by turning
all layers and classes on and do a custom
selection for text. Then change the font of
them all at once.
Patrick
Still no luck. I have pinpointed the problem though to just Greek characters, therefore I presume it has to do with the encoding which must have changed between versions.
