Solidworks has a nice feature where you can automatically merge a new solid object being drawn on an existing solid object.
E.g. when I draw a plate with a certain thickness and then want to add a vertical plate on top of it to create a side plate then Solidworks can automatically join the two into a single solid object when you extrude the 2nd shape that is drawn on the first shape. For e.g. sheet metal parts this would eliminate the step of adding solids to each other afterwards, which can save quite a bit of time if you have to do this a lot.
It would be nice if VW could have such an automatic merge option.
Art V
7 answers to this question
