Rotating Light Positions, Label legend Problems
Hi! First forum post alert!
After I select a pipe (set as lighting position) and rotate 180, the pipe disappears and label legend displays "No valid symbol selected."
Also, the containers' spacing is changed in relation to the in strument symbol. See before and after rotation screenshots. All help is appreciated!
Using VWX2016
Easy enough fix. I just had to re-run label legend and it fixed it. Not really sure why the pipe position went away though. Im guessing it has to do with how VWX recognizes the axis to rotate. I was grabbing all fixtures and pipe together. Interesting though, a curved pipe rotated with the instruments without any issues, label legend or otherwise.
