lswdw Posted September 30, 2004 Share Posted September 30, 2004 i am having problem resizing a jpeg image but i hvae no problem with an object. am i missing something? version 11 on pc Quote Link to comment
patman Posted September 30, 2004 Share Posted September 30, 2004 I just select the bitmap and drag the handles at the corner or edge. Is this not working for you? Patrick Quote Link to comment
lswdw Posted September 30, 2004 Author Share Posted September 30, 2004 yes, if i am just manually resizing it . but what i am trying to do is to import a bitmap over a scale drawing and i thought using the fix point can help me to resize to the closest scale. Quote Link to comment
jfmarch Posted September 30, 2004 Share Posted September 30, 2004 you have to scale it using a scale factor number. we do this all the time, and it works pretty good, depending on the quality of the drawing you have scanned. since you can't snap to an imported image- it is not a vector drawing- you need to measure a known area or it and scale away. hope this helps... Quote Link to comment
patman Posted September 30, 2004 Share Posted September 30, 2004 Yea, that works. If it is a survey I will draw a line over a long boundry and get the length. Then use the scale objects command and put in for the scale factor the length it should be divided by the length it is. Patrick Quote Link to comment
