Almost positive this is a bug. For me it's very repeatable.
1. Draw a round wall with the open side to the left of the screen. i.e. like a right parenthesis. )
2. insert a window EXACTLY to the right of the radius point of the wall.
3. Give the window an exterior trim so you can keep track of the inside / outside.
4. Insert the same window somewhere else in the wall.
For me the first window ALWAYS sees the inside of the radius as the exterior. Any other windows switch interior/exterior sides when the direction of the wall is reversed.
Nudging the stuck window even as much as .75º off the 0º angle fixes it.
Same problem with windows that are 180º from the radius point.
BUT the problem does not happen with windows that are 90º or 270º from the radius point.
I'll attach a file. Look at the windows in the red circles. Try reversing the direction of the walls. The windows in the circles don't change sides.
michaelk
Anyone else seeing this?
window in round wall bug.vwx
1 answer to this question
