Switching between documents is now broken. If you go to Window - and select a different document - the view will change - but the navigation will not update and all the tasks happen in the original document. Nothing seems to be happening until you switch back to the original document and its all happened there. If you select the windows tab, the tick remains by the originial document never mind if you switch between several other documents. The only fix I have found is to close all the documents. VW itself does not need to close. 'ctrl + tab' or 'alt + tab' dont seem to work either.
It goes without saying that this is a huge problem and is incredibly frustrating when working on several documents.
