There's something weird going on with Separate Sheet Views preference. I can't quite put my finger on exactly what's changed, but something has.
I wish the views for the design layers and sheet layers were separate, as this preference implies, but I would prefer if all the sheet layer views were the same. Its confusing when I switch between sheet layers and the view changes, which happens when the current preference is turned on. Its also confusing when the view changes as you switch back and forth between the design layers and the sheet layers, which happens when the current preference is turned off. Ideally there would be a separate view for design layer space and a separate view for the sheet layer space.
Kevin McAllister
Kevin
Edited by Kevin McAllisterAdded a comma
1 answer to this question
