Leonard Marsh Posted September 18, 2004 Share Posted September 18, 2004 I've read the past postings about Doodle! & SU here and found users of both strongly feel that these are tools that should be incorporated into VW or be plugins. Katie, or others, is there a real possiblity that VW/RW will be incorporating 2D functionality for Artistic Renderworks in the "near" future? How about SU's ease and speed to sketch 3D studies? Will VW/RW incorporate these features soon? Should I go ahead and buy or, should I hold off? Quote Link to comment
Bart Rammeloo Posted September 18, 2004 Share Posted September 18, 2004 Let me rephrase this: "Katie, please tell me what will be in version 11.5. If possible, I would also like to know what will be in version 12 and 12.5. I don't care wether this conflicts with NNA's strategy to never reveal anything about future releases, I want you to make an exception - especially for me." And now the reality check. NNA doesn't tell you up front what they're up to. If you have 11, you will get 11.5 for free. So if 11.5 has those features, you will get them for free. If 11.5 doesn't have them, then you will have to wait until VW has them. And if you can't wait, you have to buy either doodle or SU. Have you checked their prices? How much would you lose on betting that 11.5 doesn't have those features? Not too much, if you ask me. Bottomline: if you need it, buy it. If you can wait, wait. Cheers, BaRa Quote Link to comment
Kevin Posted September 19, 2004 Share Posted September 19, 2004 I have both Sketch Up and Doodle and VW11. As much as I like Artistic Renderworks, it does not provide the sketchy floor plans that I can get with Doodle. Doodle is not terribly expensive. My beef is that everytime I upgrade VW, I have to upgrade Doodle. Right now I do not have a current version of Doodle. SketchUp will export to VW. I tried it but have not used SU extensively. I agree that SU is a great tool. What I need to do is see how effectively I can model in SU and then transfer over to VW. Does anyone on this board use both SU and VW? Quote Link to comment
jan15 Posted September 19, 2004 Share Posted September 19, 2004 Kevin: I've used Sketchup quite a bit for 3D studies and renderings, and even for 3D sketches while field measuring existing buildings. I use VectorWorks for construction drawings, 2d sketching, and presentation graphics. I've never exported 3D models from SU to VW. In fact, I've never done any 3D work in VW. I tried it but couldn't stand the waiting. It reminded me of my nightmarish pre-Vectorworks life, drawing in Autocad on old machines, with long regeneration times when zooming. I once exported an SU model to 3ds, and someone else did a rendering from that. The rendering came out very well, and I didn't hear any feedback about problems with the export, but I didn't really ask for any feedback. I've exported VW plans to SU via DWG, but there were always problems with angles being slightly off from 90 degrees, which threw the model off terribly. Eventually I realized it was just as easy to sketch the plan in SU. It became standard for me to start a project in SU, and then later export 2D projections to VW (via DWG) for construction drawings, which worked with no problems at all. What's Doodle? Quote Link to comment
CipesDesign Posted September 19, 2004 Share Posted September 19, 2004 Hi Jan15, "Doodle" is a 3rd party plug-in of sorts that does the same thing as "Squiggle": It takes perfectly straight lines and makes them look squiggly, or doodled (as on a paper napkin). I have an old copy of it which was compatible with VW's 9xx I think. I haven't even looked at it since then. Peter Quote Link to comment
Leonard Marsh Posted September 19, 2004 Author Share Posted September 19, 2004 Hi Katie, could you provide a Nemetschek response to my question? The features of these two applications are clearly needed by designers, as has been noted by VW/RW users. Thanks. Quote Link to comment
