gogary Posted May 29, 2018 Share Posted May 29, 2018 (edited) I Need to be able to get the Dimension of Wall Length to the Outside of the Core WAll Component, in Worksheets VW Measures centerline only, which is useless many times Otherwise, LENGTH in a Wall Worksheet are INACCURATE You can id the core by name or number. Also: WallAreaGross comes up w/ odd numbers. If ComponentAreaGross was available, that would fix it. (But the only option is with minus openings). 😄 Edited May 29, 2018 by gogary correct title, clarify Quote Link to comment
gogary
Edited by gogarycorrect title, clarify
0 answers to this question
