It’s shocking how slow Vectorworks 2018 often runs on my MacBook Pro¹. Navigation and screen processing easily increases drawing time by 20-40%—even on simple 2D plans in wireframe view. It can take up to 5 seconds to simply select an object and for the object info window to load. Click–wait–manipulate object–wait–see results... repeat 500 times².
There is no question, something in VW 2018 has made it run slower than 2017 and 2016. Considering I set up VW 2018 on a fresh MBP and macOS installation, this doesn’t make sense. Open GL is already implemented, though it doesn’t seem to be helping.
Metal³ has the ability to increase graphics performance up to 10x by reducing CPU loads with efficiencies in programming and APIs. It also adds support for external GPUs.
is Metal already implemented in VW? Is it on the roadmap?
Either way, something needs to be done to boost the efficiency of VW. If it’s not a graphics bottleneck, then what is it—and is it an issue I can resolve?
MadXD
¹Specs: MBP 15” 2017 / 2.9 GHz i7 / 500 GB SSD / 16 GB Ram / Radeon Pro 560 4 GB • macOS 10.13.4
²Note: Slowdowns occur on every level of VW graphic performance settings and when VW is the only non-system app in use.
³Current version: Metal 2
17 answers to this question
