Hi,
I wonder if anyone knows who are the best way to get the height from a solid. I'm working on a single house in a sloped terrain, their wooden posts have different heights but with a standard notched end.
The Issue begins when I try to get the heights from those "solid subtractions" on the worksheets. Normally I use the "framing member tool" to get those dimensions correctly, but in this case I've to make an extra operation because the notch. I've tried to convert them in other kind of objects like "generic solid", or "extrude along path" without success, I suppose there may be a formula or something that allows me to get the dimensions I need.
Thanks!
Share this post
Link to post
Normally a generic Solid shows the XYZ dimensions of its Bounding Box in OIP
So you should be able to read its total Height.
But not not sure if that value can be extracted easily for calculations.
Share this post
Link to post
If you convert the object you need a height from into a symbol then the Z value of the insertion point will report to a worksheet. It looks to me from your picture that you maybe have only two or three types of objects to make. If there are lots of objects to replace with symbols, then select the objects and run the modify>convert>replace with symbol command.
Hope that makes sense
Share this post
Link to post
If I'm correct in assuming you're looking for the vertical length of your posts, I think you'll find what you need in this other thread -
Note that the other thread also discusses a related bug that you should be aware of, though I think you should be fine with solid subtractions or generic solids. I would go with Marissa's suggestion of using "=TOPBOUND-BOTBOUND" as your worksheet formula.
Kevin
Share this post
Link to post
You probably also need to recalculate the worksheet with the drawing in an elevation view to get the TopBound and BottomBound to calculate properly.
Share this post
Link to post
