Jainsworth 0 Posted May 21, 2018 Hi all, I have been experimenting with creating a site model of a quarry. It is quite a large dataset contour wise, and I successfully converted the 2D polys to 3D. When applying a site model however, it appers as a sort of mesh / spider web. Any suggestions? On the right hand side, I can see that the visual element is set to 3D mesh. Using Landmark 2018. Thanks Joe Quote Share this post Link to post
PVA - Jim 2,395 Posted May 21, 2018 3D Mesh would look like this, yes. You should be able to select Extruded Contours to only see the contour edges and surfaces themselves if you like. This covers that and other visual settings for Site Models in detail: 1 Quote Share this post Link to post
