David Poiron Posted May 16, 2018 Share Posted May 16, 2018 I've imported a lidar (.LAS) file into vectorworks using the import point cloud command. Is there a way to transform this into a mesh or something similar that can be manipulated? Quote Link to comment
Art V Posted May 18, 2018 Share Posted May 18, 2018 Not directly in Vectorworks, though there is software that can generate a mesh from a point cloud file. Meshlab is one of those programs. The only exception could be a lidar of a terrain without objects (or just a few small objects), i.e. just a scan of the terrain surface, then you could try using the point cloud data to generate a dtm, but there would probably be way too many points for the dtm to make this a usable option (i.e. the data set would need to be simplified quite a bit depending on the density of the point cloud). Quote Link to comment
herbieherb Posted May 22, 2018 Share Posted May 22, 2018 I use the OpenSource CloudCompare to do this kind of work. It can handle very huge point clouds. It's able to simplify them and to make meshes. Quote Link to comment
Peter Neufeld Posted June 13, 2018 Share Posted June 13, 2018 Not sure if this thread is of any use: Cheers, Peter Quote Link to comment
