relume
change layer assignment of an object | moving object to an other layer?
Hello
I am wondering if there is an easy assignment command for objects to change layers as it is for classes (vs.setClass or vs.setClassN). Can it be true, that this should be only possible by duplicating the object first (by vs.CreateDuplicateObject) and thereafter deleting the original? In the VW GUI info-Palette with the appropriate pop-list the task seems more as an reasignment than a duplication (or a hidden cut/past operation).
Many thanks in advance and best regrads,
Hi,
Can you please put up the whole script start to finish? I've seen various posts on this but I can't customise SetParent to work. I'd be super grateful if you can do this! Thanks
Hello
please find two scripts that I have created as part of libs:
# use		:	assigns a new layer to object
def object_layer_assign(vObject_Handle, vLayer_Destination_Name):
	vLayer_Destination_Handle = vs.GetLayerByName(vLayer_Destination_Name)
	if vLayer_Destination_Handle == None:
		vLayer_Actual_Handle = vs.ActLayer()
		vLayer_Actual_Name = vs.GetLName(vLayer_Actual_Handle)
		vs.Layer(vLayer_Destination_Name)
		vLayer_Destination_Handle = vs.ActLayer()
		vs.Layer(vLayer_Actual_Name)
	vs.SetParent(vObject_Handle, vLayer_Destination_Handle)
and :
# use		:	assigns a new layer to objects selected by criteria
def object_layer_assign_criteria(vSelection_Criteria, vLayer_Destination_Name):
	def object_layer_assign_iterator(vObject_Handle):
	vs.ForEachObject(object_layer_assign_iterator, vSelection_Criteria)
I hope they will be to your help,
best regards,
Thank you! I'm new to scripting so I'll try work with this. Might need to repost for some help later. Cheers.
