DomC
Set Record Popup Field
Hi
I can remember I had this issue in past. Unfortunately I can't remember and am not able to find the solution with the forum search. Somebody knows the solution?
Trying to change Value from Poupup Record Field.
1522377148_Bildschirmfoto2018-05-14um18_02_45.thumb.png.943431f9950a9675fe7150453dd7e8f9.png
ChangePopupValue.vwx
@Alan WoodwellThanks for quick response
Unfortunately the set Record Nodes (and the vs.SetRecordField), do not work on pupup fields without a further trick.
Posted (edited)
Seems I have somehow to trigger a change of the record format. At the moment the only workaround is to attach a new field to the record format which regenerate the info-palette popup.
vs.NewField(record,'92d34ddb-8b38-4053-b688-4b3b960f5911.','0',4,0)
Also tested vs.GetObjectVariablexxxx from 1 to 10000
vs.ResetObject(record)
... nothing help.
Edited by DomC
