Jeff Cooper
2018 Silent Install Not Storing Username or CompName
Hi All,
When I run the command-line installer for a silent install, and set the user and company names, I am still prompted with "Personalize Your Copy of VW" dialog.
Here's the command (serial redacted of course):
/Volumes/Vectorworks2018-SP3-418943-SeriesB-installer5-osx/Vectorworks\ 2018\ Installer.app/Contents/Resources/installer/Install\ Vectorworks2018.app/Contents/MacOS/installbuilder.sh --unattendedmodeui none --mode unattended --Serial <SERIAL#HERE> --UserName "Jeff Cooper" --CompName "King + King Architects" --installdir "/Applications/Vectorworks 2018"
I used this method when we did 2017 and it worked like a charm. Any suggestions?
Thanks,
Jeff
4 answers to this question
Jeff, here you have an article with instructions for 2018 :
Saludos,
Hi Juan,
Thanks, I was actually using this to build the command I'm using. But UserName and CompName do not get set.
Thanks,
Jeff
Hi @Jeff Cooper, I know I'm a little late to the party, but I've figured this out.  I was going through the installer log and noticed that running this command sets the UserName and CompName to the vectorworks plist in the root user's home folder.  I decided to try setting the same plist keys into the root level plist (/Library/Preferences/net.nemetschek.vectorworks.2018.plist) and voila, the Username & Company Name started working.
For your reference, here's the 2 defaults write commands that I used:
defaults write "/Library/Preferences/net.nemetschek.vectorworks.2018" "NNA Registered User" 'Username'
defaults write "/Library/Preferences/net.nemetschek.vectorworks.2018" "NNA Registered Organization" 'Company Name'
And (in case you're interested) here's a post-install script I wrote that does the following:
  1. Mounts the dmg file silently (the pkg I made puts the installer dmg into "/tmp/VW2018/")
  2. Installs the software
  3. Unmounts the dmg
  4. makes a directory for the "LoginDialog.xml" file
  5. Copies the "LoginDialog.xml" file into place (again, I've put this file into "/tmp/VW2018/")
  6. Runs the 2 defaults commands to set User Name and Company Name
#!/bin/bash
## postinstall
hdiutil attach -nobrowse "/private/tmp/VW2018/Vectorworks2018-SP4-435714-SeriesB-installer1-osx.dmg"
"/Volumes/Vectorworks2018-SP4-435714-SeriesB-installer1-osx/Vectorworks 2018 Installer.app/Contents/Resources/installer/Install Vectorworks2018.app/Contents/MacOS/installbuilder.sh" --unattendedmodeui none --mode unattended --Serial "SERIAL-NUMBER-XGOESX-XHEREX" --UserName "Username" --CompName "Company Name" --installdir "/Applications/Vectorworks 2018"
hdiutil detach "/Volumes/Vectorworks2018-SP4-435714-SeriesB-installer1-osx"
mkdir "/Applications/Vectorworks 2018/Settings/SeriesG"
cp "/private/tmp/VW2018/LoginDialog.xml" "/Applications/Vectorworks 2018/Settings/SeriesG/LoginDialog.xml"
exit
Hope this helps!
Edited by YukonLuke
