Phil Schawe Posted May 9, 2018 Share Posted May 9, 2018 Using the Column plug-in tool, I'm having trouble applying a stone texture to the column base. I gave the base a class color in the Settings dialog box, and I associated a stone texture with the class color, but the base doesn't render the texture. Any ideas what I'm doing wrong? Thanks. Phil VW 2016 Column.tif Quote Link to comment
cberg Posted May 9, 2018 Share Posted May 9, 2018 I'm in VW 2018 and I was able to set different textures to different parts of the column. Have you set all attributes by class in the attributes for the column? In your classes have you set all the textures to be used at creation? Quote Link to comment
Phil Schawe Posted May 10, 2018 Author Share Posted May 10, 2018 yes, sir. with 2016 the option is to assign a class texture to 'other', rather than roof and walls. I've done that. Everything else I have done as you suggest. Quote Link to comment
