Sebastiaan
Workgroup Folder dissapeared
For some reason the workgroup folder I had set up and was working in the past year has dissapeared from my Recource manager. And I can't seem to get it back.
I have set up the folder using the :"[Workgroup]\Libraries\[folder name]" naming of the folders. But the files do not appear in my Recource manager again.
I do not want them back in my favourite file as this results in a lot of lag in using the recource manager. Attached are printscreens of my recource manager and folder structure.
The files are on a dropbox folder also.
Any ideas what happened or if I am doing something wrong?
I am running vwx 2018 SP3 on a mac with OS version 10.12.6
8 answers to this question
@SebastiaanHi I think your directory has gone one file too far. Stop at WorkgroupSTB in your case.
HTH
HTH
Unfortunatlely this didn't solve the problem. I restarted VWX and refreshed the libraries after setting up again. The silly thing is that is was working fin before and dissapeared out of the blue. Just not sure how long it was since I updated to SP3. I noticed it about a week and a half ago.
The files are in the folder and they are all 2018 files.
Solved. Workgroup folder needs to be named: Vectorworks Workgroup Files and should then contain a libraries folder containing the files.
I am am quite sure I had in named differently before but it works again now.
This isn't true, but I'm glad that it's now working for you!
I keep my Workgroup folder in my OneDrive account right at the root, so that naming convention is not necessary.
Ok so indeed i changed the folder name to something different and it is working still. I don't know wat happened or what i did in between but I am happy it is working again too.
Doesn't work for me. No solution in VWX 2019, alas. (Mac). Tried all this and no joy. Reverting to Dropbox folder with files but giving up on making it a workgroup folder (renamed, restarted, etc. etc.) Wasted an hour of my time on this horrible thing and that's enough.
I'll just have an accessible Dropbox folder with my symbols etc. inside that I'll just open in VectorWorks and import through the Resource Browser.
Nobody else in the office even tried to mess with this nightmare (needs to be simple, not übergeek level!
Edited by Luciole Design
added information
I'm having this issue. Folder working on colleague's Landmark 2020, but after directing to same folder in my 2020 Designer, it is not showing up, even after multiple restart and refresh
