gettinalllandscapey Posted May 9, 2018 Share Posted May 9, 2018 Problem: I select a symbol and complete a dup along path command (from basic tools) which goes great. Then, after a lot more work, alterations to the drawing, coffee, saves and minutes later I use command+Z. Takes me straight back to before the dup along path view. Removes all work completed after that command. Solution: ??? No idea, probably a bug. Quote Link to comment
0 Vectorworks, Inc Employee PVA - Admin Posted May 9, 2018 Vectorworks, Inc Employee Share Posted May 9, 2018 With just these steps in a test file, I am unable to replicate this in 2018 Sp3. What service pack are you currently using? Does the same thing happen for you in a new blank test file, creating a path, duplicating the same symbol along it? If you can send me the file where it occurs, I can take a look. Direct message is fine to keep the file private. Quote Link to comment
gettinalllandscapey
Problem:
Solution:
1 answer to this question
