Rotate Points Grid
I wrote a script that creates a grid of rectangles (to be a column grid) based on points a set distance away from each other within a polyline boundary. How can I rotate the grid so that rather than the rectangles being rotated relative to the world XY, the GRID is rotated to align with the polyline (i.e., the grid's rotation is the same as the polyline, so the rectangles are rotated 0deg relative to the polyline). Part 1 is the script as it stands and Part 2 is the script when it's run.
