Previous versions set Database Sub-Row heights to the Header Row's height by default, in 2018 the Sub-Rows default to Auto Fit regardless of the Header's setting, which results in image cells creating variable, uneven worksheets. It's a minor irritation I know, but if you like to maintain consistent appearances, Worksheets now require editing every time they're introduced or changed.
Worksheet Database Sub-Row heights can now be set individually, which adds flexibility, but I'd like an option to return the previous default behaviour, such as the check box indicated below.
M5d
1 answer to this question
