Bernd Lützelberger Posted May 6, 2018 Share Posted May 6, 2018 I tried to go though the instructions of the white paper attached from german VSS forum rebuilding the network for a ramp. Unfortunatly without success of seeing the expected result getting stuck on side 30 of the pdf. Maybe somebody can help on the way and find my fault? I tried with different kinds of polylines and settigns of the controls in the oip of the loft surface node , that make different effects, but strange.... . thanx and friendly regards BerndL 2018_05_VSS_White_Paper_Ramp.vwx 2018_04_27_VSS_VW_2018_White_Paper_Marionette.pdf Quote Link to comment
AlanW Posted May 6, 2018 Share Posted May 6, 2018 @Bernd LützelbergerHi I can't see why it fails so far but looking at that wrapper is enough to do your head in. Quote Link to comment
Vectorworks, Inc Employee SBarrettWalker Posted May 7, 2018 Vectorworks, Inc Employee Share Posted May 7, 2018 Hello @Bernd Lützelberger, I noticed in all of your scripts that the Int node is somehow connected to the first Range node twice, which is causing you to get 42 values instead of 21 values - if you try disconnecting it and reconnecting it should work. just make sure that when you run in debug mode, there are 21 values coming from the Range node. Quote Link to comment
AlanW Posted May 7, 2018 Share Posted May 7, 2018 @sbarrett Hi, I did as you said and i get this, the ramp nodes are there but no connection, do you get the solid ramp?? Quote Link to comment
Vectorworks, Inc Employee SBarrettWalker Posted May 7, 2018 Vectorworks, Inc Employee Share Posted May 7, 2018 Ah, for that issue, you simply need to check "rule" in the Loft Surface node. That will give you sharp edges. Quote Link to comment
Bernd Lützelberger Posted May 7, 2018 Author Share Posted May 7, 2018 Dear Sarah Barrett, dear Alan Woodwell, thanks a lot for taking care of my issue. And finding the fault! I took of the double connection, and it works fine. Quote Link to comment
AlanW Posted May 7, 2018 Share Posted May 7, 2018 (edited) @sbarrettThanks, Ruled and solid that worked. @Bernd LützelbergerHi, thanks for sharing the document. Nice that someone took the time to produce such a fine paper. Is there any more around like this and can i get an English translation. Using Google translate at present. And you can push the network with a more complex line a long way before it will fail. Edited May 7, 2018 by Alan Woodwell Quote Link to comment
Bernd Lützelberger Posted May 8, 2018 Author Share Posted May 8, 2018 Dear Alan Woodwell. Thank You for further answer. I sent your request towards english version of pdf / further marionette white papers within a feedback mail to the german Vector works company . As far as I know , this white paper is the only one about marionette. Friendly regards BerndL Quote Link to comment
Vectorworks, Inc Employee SBarrettWalker Posted May 8, 2018 Vectorworks, Inc Employee Share Posted May 8, 2018 @Alan Woodwell This paper is on the Vectorworks website here: http://www.vectorworks.net/training/2018/getting-started-guides/transitioning-to-vectorworks/moving-from-grasshopper Quote Link to comment
