AlanW Posted May 3, 2018 Share Posted May 3, 2018 Refer to attached, Trying to use the IF node with a radio button and it outputs 0,1, 2 etc as integer (so it says) but i cant get ti to trigger the If Node. What am i Missing?? If_Node_Deleting_Objects copy v2018.vwx Quote Link to comment
Marionette Maven Marissa Farrell Posted May 3, 2018 Marionette Maven Share Posted May 3, 2018 Hey Alan, So the issue isn't with your Radio Button node, the problem is you named that other input node '1' We can't have '1' as a name for a node, if you change that to 'one' the network will work. Quote Link to comment
AlanW Posted May 3, 2018 Author Share Posted May 3, 2018 (edited) Hi, it works with the REAL node, I can put 0,1 or 2 and it triggers Ok and i see if i change the Int node as you say it works , Thanks Edited May 3, 2018 by Alan Woodwell Quote Link to comment
Marionette Maven Marissa Farrell Posted May 3, 2018 Marionette Maven Share Posted May 3, 2018 You didn't name the Real node '1'. Rename this node from '1' to 'one' Quote Link to comment
AlanW Posted May 3, 2018 Author Share Posted May 3, 2018 Ah Ha i see. Thanks again. 😊 Quote Link to comment
