It would be really useful to have 'Multi-Layer Symbols' - These would be symbols that would appear on multip design layers. Similar to how the section tags work - you would first check the symbol option box "Multi-Layer" and then select the layers that you want that symbol to appear. This would oddly probably be an instance based setting.
The most obvious use would be for vertical elements like elevators, risers, etc that stack vertically. That way you can create your symbol, then select the layers that it should appear rather than having to have multiple instances of the symbol which can sometimes become unaligned.
Tom Klaber
4 answers to this question
