Scott61 Posted April 26, 2018 Share Posted April 26, 2018 Hi, i am having an issue with the sweep command. I drew a rectangle, put a locus around which I want the sweep. But the command does not go around the locus, it acts as if it does not see the locus. Have I missed something?? Quote Link to comment
Andy Broomell Posted April 26, 2018 Share Posted April 26, 2018 The Sweep command only looks in a left-and-right fashion - it considers only the horizontal distance between the locus and the profile shape. So you'll want to rotate both things 90°, create the sweep, then rotate back 90°. Quote Link to comment
Diego - Resuelvector Posted April 27, 2018 Share Posted April 27, 2018 Also, don’t forget to select the rectangle and the 2D locus, before making the sweep. Quote Link to comment
