Marionette Node List
  • 5 months later...
  • 2 weeks later...
This is AMAZING and worked the very first time for me.  Thank you!
It is worth noting that the alignments only work correctly if text is preset to justify left and top.  And the design layer scale must be 1:1.  And for some reason it put in VERY large text some unrelated text I'd typed in and then corrected recently in another file.  Both of those strings came in.  Does that have anything to do with the vsGetTextNode section at the top?
Thank you, thank you, thank you!
Edited by Cris Dopher
Hi Cris,
I'm glad you liked it!
I am not sure what is happening, but can you try changing the font?
In line 57, there is "vs.SetTextFont" and the name of the font is indicated in the parameter of vs.GetFontID.
You can change the font used by setting the font name where a Japanese font is set currently.
Also, maybe you can delete this line to have document font used.
Regards,
Takeshi
