Coombed
AnimationWorks - 20 Objects Max'?
Hi All,
I have the need to rotate 100 cubes for a visualisation using the AnimationWorks plugin. However, AW will only allow 20 objects, thus missing out the remaining 80.
Is this normal?
Thanks
Duncan
Solved!
Courtesy of Julian @ OzCad:
The default maximum is 20 and this is just to reduce the memory requirements. You can change this however by opening the AW_Constants.vss file in a text editor. This file is in the Plug-Ins/Data folder. Once you have the file open, scroll down to line 70 and look for this:
kRotateObjectLimit = 20; { max number of rotation PIO objects on each layer }
Just be aware that increasing some of these limits can increase the processing time.
