miguelcanido Posted April 19, 2018 Share Posted April 19, 2018 Hi, I need Help, my english is not good. To calculate the component area by name from the walls. I have this formula: =COMPAREABYNAME(T=WALL, 'LADRILLO') This formula works but take all the layers at the same result. How would it be the correct formula to separate the result by layers? Thanks Quote Link to comment
Pat Stanford Posted April 19, 2018 Share Posted April 19, 2018 The first part of the function takes a criteria to allow you to specify exactly what you need. Explore the Insert Criteria function or the help for more details. Short answer change the T=Wall to ((L='Design Layer-2') & (T=WALL)) where you can change Design Layer-2 to any layer you choose. Ask again if you need more information. Quote Link to comment
