ford519 Posted April 18, 2018 Share Posted April 18, 2018 Hi there. I have a large arc I need to dimension... is there a foreshortened dimension tool in Vectorworks? Or maybe a jogged arc dimension tool? Thanks! Quote Link to comment
0 markdd Posted April 18, 2018 Share Posted April 18, 2018 The simple answer is no, not as far as I am aware. A good workaround is to dimension the arc as normal and then ungroup it. That will break it up into its basic geometry which you can then edit to be what you want to see. Quote Link to comment
0 Jim Smith Posted April 18, 2018 Share Posted April 18, 2018 Add it to the wish list, I'd like to see that, as well as other enhancements to the Arc & Angle Dimension tool. Quote Link to comment
0 AlanW Posted April 19, 2018 Share Posted April 19, 2018 Have you tried editing you dimension style to get what you want? If I understand you you want the dim line to be shorter, adjust in style or create a new style. HTH Quote Link to comment
ford519
Thanks!
3 answers to this question
